How to remove the snap-on Rear Case from Samsung LED TV (DN7200)?
Got a new TV and attempted to mount it with my old TV’s wall mount. Basically, the screw went into the hole, and there is a lip on the case of the TV that is not allowing the screw to come back out as it was too short.
I’ve tried sticking 3M onto a screw driver and trying to pull it back out, but it doesn’t hold strong enough and I think I just need to remove the back case.
There are no screws holding the case down that I can see, just two U-shaped holes on the back case right where it meets the front bezel that look like it might be a pry point for getting to clips/snaps holding the case down, but I just wasn’t positive.
Does anybody have any experience with these? Thanks in advance!
Corey
Es esta una buena pregunta?
@coreyrogers89 double check your model number. Also post some images of that back of your TV as well as the label that is fixed to the back. That way we can see what you see. Use this guide Agregar imágenes a una pregunta existente for that
- de oldturkey03
