Will my Samsung TV work in Europe?
Hi,
I’m moving to Europe and I was wondering if my fairly new TV set would work there (https://www.samsung.com/us/televisions-h...). Technical specs says it’s 110-120v & 50/60 hz so I’m guessing it would not work?
If it does would it need a voltage transformer?
Thanks
Es esta una buena pregunta?
1 comentario
Hi Augustine, thanks for the quick reply.
As I understand from your reply, as long as the power board is labelled as 110-220v &50-60hz as input, a simple power cable change will do the trick, eventhough the external label on the TV says its 110v?
If so, as you’ve said I can either check the power board on the tv, or find out which power board this model uses and the power boards specs,
Thanks a bunch.
If anyone likes to add more info, please feel free to do so.
- de sffixers
