Charging port not working
I have an ipad A1567 and can not find any info on it. The fire port needs replaced. How can I find it?
Es esta una buena pregunta?
Another option is to have the charge port replaced by a repair shop that does micro-soldering repairs. It should be less expensive than replacing the board.
Fue útil esta respuesta?
From a quick search I found that your device has its charging port soldered to the motherboard. Just look in the store for the logic board of your device instead.
yes but i do not see that ifixit sells this part :(
Yes but i do not see that ifixit sells it :(
This is the part you are probably looking for. iPad 4 Lightning Connector MAKE SURE IT IS RIGHT FOR YOUR MODEL. It should be an iPad 4th Gen Retina A1458, A1459, or A1460
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 123
