Neato Botvac D80 issue.
I own 2 of these units (identical). By swapping a couple parts I have determined that the battery, and charger base are not the problem. Bad unit has no power at all. If I put it on the base to charge, Home button lights up green, tells me to turn the switch on (it’s already turned on, but I press ok anyways). Home button turns to amber (slow blink to indicate charging has started). After between 10-30 seconds, it changes to rapid amber blinking on home button and after about 3 seconds it shuts down, reboots and starts the process all over. Ideas?
Es esta una buena pregunta?
Hi Jeff, got the exact same problem. Figured it had to be a faulty on/off button so I swapped it for a new one, only to find out that was not it...Did you ever find out what the problem was?
- de Frankdreis
