Audio amplifier has short circuit
Hi,I am repairing an audio power amplifier…I don't see any damaged parts but the light bulb indicates that it has a big short circuit…its peavey cs 2000 power amplifier
pls help
Es esta una buena pregunta?
pls help
Make, model and a few pictures of the boards inside would help. You give us little to go on here. In general, with a direct short like this, look at the bridge rectifier being shorted (if there is one) or if this has a switching power supply, check the main transistor (should be on a heatsink).
Update this with the above info and we should be able to provide more detailed suggestions.
Fue útil esta respuesta?
I am unable to upload images but its peavey cs 2000 power amplifier
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 1,958
Is your amp repaired??
- de Mallon Mbewe
Hi im roldan from cebu .my question is..what can i do the speaker out is bad tune ( mahina parang short ,)not fully higher tune.im using 1 channel only cause the other channel is broken .
Thank you.
- de Kuya Reinz Bustillo
Hi @Kuya Reinz Bustillo,
What is the make and model number of the amp?
- de jayeff
Ask ko lang po kung na short circuit yung amplifier means madadamay po ba yung speaker ? Salamat po
- de Michael Geronimo
