Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
Preguntas 1434 Ver todo
Apple Hardware Test Failure Code: Help
Hello Everyone,
I was just playing around with my macbook 4,1 and decided to do Apple Hardware Test. Which resulted in
failure code: 4SNS/1/40000001: VG0C-0.070
I did some research and seem to indicate a sensor failure on the logic board. Though I have not had any no problems with this laptop for the last 8months(2nd owner) I was wondering if anyone could shed some more light on this error code and if I should be concerned
Thanks
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 3
Comentarios:
good job. Thanks for sharing.
por
Thanks for sharing. Its helps me alot
por
i am also facing the same code error. but unable to resolve it. kindly help me too to resolve this problem
https://www.puspack.com/
por
I did some research and seem to indicate a sensor failure on the logic board.I was wondering if anyone could shed some more light on this error code and if I should be concerned.If you face any issue in Your Charger. Then you can Buy Lenovo laptop charger in Dubai.
https://laptopcharger.ae/lenovo.html
por
Some eventual surprise, yet managing them was frequently great preparing at being emphatic and beating protests. A large portion of them are not awesome customers, which is the reason they are getting partaken in any case. In any case, it was a decent chance to sharpen my aptitudes and achieve a general gathering of individuals.
https://24hwritemyessay.com/online-essay...
por
Agregar un comentario
7 Respuestas
Solución Elegida
Apple doesn't tell the peons what those codes mean. But if you would like to spend about $47.50 they will tell you. Just call 1-800-SOS-APPLE. But my opinion is, "if it ain't broke, don't fix it".
Fue útil esta respuesta?
Calificación 5
You could try running Techtool Pro from Micromat.
I used to be Mac Certified - and I couldn't get error code info ?? !
Calificación 1
Run the extended version of the Apple Hardware Test. Sometimes you will get an error if you run the quick version, and it may be something of a false positive. Some have found doing an SMC reset 3 or 4X can eliminate the error (note: a work around not a fix). If it is indeed a logic board error it points to a sensor(s) failing, VPOR might be VGC(VPU) related. You'll probably need a new logic board, AFAIK sensors as well as the VGC are soldered to the logic board which pretty much makes them non-DIY repairs, as soldering on logic boards are not for amateurs.
Calificación 0
Sometimes you will get an mistakes if you run the fast model, and it may be some thing of a false wonderful. Some have located doing an SMC reset 3 or 4X can get rid of the mistake note a workaround no longer a restoration. If it is certainly a logic board error it points to a sensor failing, VPOR might be VGC(VPU) related. You'll probably want a brand new good judgment board AFAIK sensors in addition to the VGC are soldered to the logic board which pretty tons makes them non-DIY upkeep Pay someone to write my essay for me UK Cheap.
Calificación 0
I did a few research and seem to suggest a sensor failure at the logic board. Though I have no longer had any no issues with this laptop for the final 8months 2d proprietor I become thinking if anybody ought to shed some extra mild on this blunders code and if I must be worried Essay help UK.
Calificación 0
The fundamental hardware test software Apple Hardware Test ''that comes shipped with the laptop is prone to leave out hardware problems, as I have been in this case regularly: it did not stumble on the pictures card difficulty on MacBook seasoned 2011+ laptops, which after years of users complaining approximately it and going through proceedings at least they refunded users, Essay Help it didn't hit upon a defective RAM that my pc had from their factory, and so forth.
Calificación 0
Real hardware failure is uncommon, however, it does happen now and again; the most common hardware failure is random-access reminiscence RAM. The Apple hardware check can check your Mac's RAM and will let you realize of any problems with it. With many Mac models, you could replace faulty RAM your self, and save some bucks in the manner. Coursework Help
Calificación 0
Añadir tu respuesta
Jamie estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 3
Últimos 7 Días: 11
Últimos 30 Días: 66
Todo El Tiempo: 1,900
