Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
Preguntas 1434 Ver todo
New Problem! Folder/No HD on startup, after 2 minute turns to apple!
anyone ever seen this? It starts as the flashing "no folder" sign for 2 minutes, then the folder turns to an apple and it starts up and runs perfect! This is definitely new to me, anyone know why this would happen? Thanks!
Update
computer had the wrong ram! one 533 and one 667, problem solved.
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Comentarios:
Congratulations on getting your problem solved.
por
Agregar un comentario
2 Respuestas
Solución Elegida
Sounds like your hard drive is starting to fail. Back it up ASAP. Then start up from your system installation disk by inserting the disk and holding down the "C" key on startup. Go to the second screen pull down menu to Utilities > Disk Utility. Select your drive on the left and see if you can repair it.
Fue útil esta respuesta?
Calificación 4
Comentarios:
that was my first thought too, but its happened on two different hard drives on this computer? this hard drive functions fine in another black macbook. ill do some testing with it and see if i can narrow it to a failing drive.
por
Try the drive in an external enclosure and see if you get the same results. Now this does not sound like a bad hard drive. Hopefully it's a bad cable.
por
got it. the previous owner had one 533mhz stick of ram and one 667. computer was confused or something, swapped it out and it works fine.
por
I've seen this when a HD that was formated and installed in another computer is beeing used. Somehow the system seems to take a while to find the "bootstrap".
Try reformating and installing on that particular machine.
Calificación 2
Comentarios:
thats exactly what happened, i borrowed the HD to test as this computer did not come with one. thanks, i am still looking to buy hard drives but the stupid a1181 "sleds" or whatever you wnat to call them are not easy to come by
por
Añadir tu respuesta
Steve estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 338
