Screen repair not working
I just changed over to a new screen and nothing is coming on what should i do.
Es esta una buena pregunta?
Sounds like you have blown the backlight.
Can you confirm that you disconnected the battey when fitting the screen?
If it's not backlight related you probably have a bad screen with no display.
Also check the flex cables on the screen that theyhave tape over any of the solder joints as this can short the screen out.
Fue útil esta respuesta?
Yes I checked all the points and the battery was drained and disconnected during the process
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 51
2 comentarios
Hello! Can you verify if its just the display not coming on, or is the entire phone not turning on? A good way to check is to make sure the phone has a charge, and attempt to turn it on. After waiting a minute or two, flip the ringer switch on the side, and if it vibrates, the phone is on.
- de Jonathan Mechels
Yes i can verify it was working before with another screen and the screen cracked so I replaced it and the new screen does not work.
- de Aiden Schafer
