Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
La Keurig modelo K70 es un sistema de preparación de bebidas para uso doméstico y comercial. La Keurig es fabricada por la empresa estadounidense Keurig Green Mountain.
Not Brewing full cups or any water period!
The only time my Keurig brews is if I hold the overflow holes… it's like there is no pressure. Also it says de-scaling and idk what that is... Please help me I literally watched so much videos on YouTube…. Clean the needle… all that stuff they tried…
Es esta una buena pregunta?
Puntuación 0
2 comentarios
Thank you for the suggestion here is the things I did so far…
White Vinegar (diluted just a little)
Clean everywhere
Force water through the thing with a turkey baster
Used compressed air to try and flush it out.
The only thing that helped any water come out was to cover the holes on the overflow valve…
- de
So I found a walkthrough that deals with the vacuum system which could be your problem. Cómo usar la cafetera Keurig K75 Platinum
Good luck!
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Descaling removes the white stuff that builds up inside your coffee machine. As the machine heats the water it causes some of it to evaporate and leave minerals behind which will cause your problem. Descaling is what you need to do to fix it.
Apparently, Keurig sells a descaling solution, but you can also just use vinegar.
https://m.keurig.com/descale-instruction...
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Wehi & Ricky DeMello estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 13
Todo El Tiempo: 315
