76 280c e brake doesnt fully release on drivers side
when brakes applied they hold when released drivers wheel moves harder than passanger side how do you adjust the shoes and cable equalizer
Es esta una buena pregunta?
Reparación de automóviles y camiones fabricados por el fabricante de automóviles alemán Mercedes-Benz.
Rep: 1
Hi there!
Start with taking the wheel off. Take a good light and look through the bolt holes and you should see like a gear with teeth. You need to adjust it either up or down a little with a flathead screwdriver. and when you have turned it a little bit just try turning the brake disc with hands and see if it is free or got even tighter!
The sweet spot is when it is grabbing the disc a bit. And when you think it’s okay try pulling the handbrake and see if you can turn it. If not it is okay and try doing the same thing to the other side as you want both wheels to be held by the handbrake with the same strength!
Hope this helps!
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 18
