Saltar al contenido principal
Lanzado el 4 de noviembre de 2017. Modelo A1865, A1901. Disponible como GSM o CDMA / 64 o 256 GB / Silver o Space Gray. (Se pronuncia igual que "iPhone 10.")
Preguntas 1198 Ver todo
Unable to activate after restore
The phone was ran over by a semi, and would freeze whenever you would try to unlock it with a passcode or face id. I have restored the phone to iOS 12.1 and now it says “Unable to reach activation server”. The phone does recognize the sim, and shows service, it just won’t activate. I have tried activating through iTunes, with no luck. 3uTools gets stuck for a few minutes on “Obtaining activation data”, then it says that it failed to activate. It is an AT&T phone, and we have already tried a new sim card. After swapping the boards out with another phone I have figured out that it is board level. What could be causing this in particular? I cannot see any damage to the board, however with the board being stacked, there could be damage that is not seen. Any help is appreciated.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
2 Respuestas
Respuesta Más Útil
the baseband cpu is responsible for that
Fue útil esta respuesta?
Puntuación 1
There could very well be damage to the broad. Try replacing it!!
Puntuación 0
2 comentarios:
I know that the issue is the board, I just need to know what part, on the board, controls the activation data, that way I can get an accurate quote from a board repair service.
- de
It is because the SIM card is not supported. If not use this guide:https://support.apple.com/en-us/HT201407
- de
Añadir tu respuesta
Ian estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 912
