My phone was summerged on water, after that doesn't work anymore.
They told me we have to replace a paper that is inside the phone. how I can do it?
Es esta una buena pregunta?
not quite sure what paper you are referring to. What you have to do is the same as for any other submerged phone. First, you need to not try to charge, sync or otherwise use your phone. This potentially can make a bad situation worse.This may further damage your phone.
The next thing to do is to clean it. Disassemble your phone using these guides . You must remove all EMI shields from the circuit board. If you do not remove those, you might as well not do anything. After you removed those, clean the whole board, connectors and all with +90% isopropyl alcohol. Follow this guide , and even so it was written for a 3G all the points are still pertinent to your phone. While you clean your board, check for any obvious damage, like burned or missing components etc. When it is properly cleaned, replace the battery. Best thing to do would be to clean it with an ultrasonic cleaner, but if you do not have access to one, this will at least help. Once all this is done, reassemble your phone and reevaluate. Until it is cleaned, everything will only be a guess.
Fue útil esta respuesta?
Actually, its not enough to dry it our by hand. You need to go to a rep center who has the right technology to save your device. Otherwise you will never get the corrosion on the components out. I know that my local rep center works with this company, Techsave who has a technology that saves phones and the data on it. Might be a something worth checking out.
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 6
Todo El Tiempo: 47
