Saltar al contenido principal
Generación final del Pontiac Grand Am.
Preguntas 150 Ver todo
Why wont my car crank?
Parked car at work, got done with work, all dash light came on normally, turned the ignition to start, nothing. Towed car home, replaced entire ignition switch assembly, let the car relearn, nothing. jumped the pins on starter relay starter cranked, replaced relay, nothing. Any Ideas????
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Sounds like it must be open wiring between ign. switch and relay somewhere. If automatic trans it may be the interlock switches that prevent starting except in neutral or park positions (typically). I would try jiggling the shifter first to see if it will help get a complete circuit to your apparently good relay.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
David Lindorff estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 45
