Saltar al contenido principal
Fix Your Stuff
Right to Repair
Parts & Tools
A1708/EMC 3164 — Released June 2017, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar).
Preguntas 172 Ver todo
Replace Logic Board to Upgrade Specs
Hey guys, I’m aware that since my cpu and memory is soldered to the logic board, that I personally can’t swap out memory sticks to upgrade my ram for example. However, is it possible to purchase a new logic board with 16GB of ram (I currently have 8GB ram) instead of buying a whole new macbook pro? Thank you
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Solución Elegida
Problem might be finding the logic board in the market since it’s a relatively new model, but the replacement can be done, besides specs shape is the same. Unfortunately there seems to be not yet a guide on IFixit to help you. Pay special attention to the smaller connectors of loudspeakers, keyboard and relevant backlight and make sure you have a spudger to help you in the job. Watching guides of previous models will help you figure out how to correctly remove parts. If you live in an area with dry weather conditions you may want to ground yourself to avoid triggering static charges.
Fue útil esta respuesta?
Puntuación 3
Comentarios:
Yes, a ESD mat and strap is a must in dry climates or in the winter!
You still might find buying a newer system will end up being cheaper after selling yours.
- Por
Añadir tu respuesta
Lachie Woodards estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 21
Todo El Tiempo: 102
