Keyboard has stopped working
Hello all,
i had recently upgraded my a1342 which meant taking it apart completely. Now once putting it back together, everything works just fine, except my keyboard. I’ve tried putting the cable back in, resetting my SMC (which doesn’t work since my keys don’t work) and it’s got the most recent update of OS. I’m not sure what other fix to try. Please and thank you!
Update (10/31/2018)
here is my ribbon in the slot. The lever is still working and it seems to be in as far as it can go. Is it possible the ribbon is misconnected on the keyboard side?
Es esta una buena pregunta?
4 comentarios
What do you mean you took it apart completely? What did you upgrade? the RAM? the Drive? Did you take the logic board out?
- de Dan
I upgrade the Ram, upgrade the Hard drive and dusted off the logic board, so yes I removed it. All cables are plugged in and I have the keyboard cable plugged in as far as it can go without breaking it.
- de Cole Reindl
Does it power up from the keyboard?
- de mayer
It powers up from the button in the top right, yes. But not a single key works. So I'm using an external bluetooth keyboard, but trying to see if its just software issue or something that can be quickly fixed
- de Cole Reindl
