Saltar al contenido principal
Películas, música, multimedia en tu hogar. Utiliza nuestras guías para reparar dispositivos de entretenimiento en el hogar, desde receptores A/V de sonido envolvente o receptores estéreo convencionales hasta amplificadores de potencia, preamplificadores, altavoces y sistemas de altavoces iPod/Bluetooth.
Preguntas 4593 Ver todo
Pregunta Cerrada
Types of surge protectors
My TV was fried last year during a "brownout" and almost none of the MANY surge protectors on the market say they protect against power "sags" or brownouts (the few I've seen are +$200!!) Won't a UPS protect against damage as long as you turn things (ie tv, stereo, computer) off before the battery dies?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
The most common types of UPS are standby UPS. It will run your device off of the normal utility power until it detects a problem. At that point, it very quickly turns on a power inverter and runs the device off the UPS battery. The power inverter simply turns the DC power delivered by the battery into 120-volt AC power. The more reliable and higher priced UPS is a continuous UPS. The plugged in device is always running off battery power and the battery is continuously being recharged. The battery charger continuously produces DC power, which the inverter continuously turns into 120-volt AC power. If the power fails, the battery provides power to the inverter. Since there is no switch over time it provides a very stable source of power. So this would be the one that would not be bothered by "brown-outs" etc. In theory any of your devices plugged into any of the UPS should be protected as long as it has a very quick switch time. Yes, you could turn your device off in case of power failure etc. and thus protect them from damage. However, even if you do not turn them off, there should be no damage since it will simply power down due to lack of AC power. Hope this helps and is not to confusing....:-) I appear to be long winded today. Good Luck
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
+ variations in current will also cause hard drive writing failures. Just don't use a laser printer on one. Here's a bunch, I like the big boys: http://www.amazon.com/b?ie=UTF8&node=764...
- de
If one is really ambitious, the construction of a continuous UPS is actually within the DIY'er capabilities ;-) everybody should have one...
- de
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 236
