Saltar al contenido principal
Lanzado en Septiembre 16, 2016. Modelos 1660, 1778. Disponible en GSM o CDMA / 32, 128, o 256 GB / Oro Rosa, Oro, Plata, Negro Mate y Negro Brillante.
Preguntas 2264 Ver todo
iPhone 7 stuck on Apple logo when Chargingport Ribboncable is in place
Hello Community, i could cry, after changing the whole Housing from my iPhone 7, if i click the ribbon connector into the Mainboard, the Phone shuts down and keeps bootlooping, when i disconnect it, it does actually boot up, but no signal, sound and vibration, so… i‘ve replaced the charging flexcable, did a before built in and after, before i‘ve built it in, it actually charged etc. after it was in there, i could again not start it, im honestly so sad, its just rediculous, when i plug in the old flexcable (without it being srewed in and stuff) it will start and charge…. does anybody have clue? i would greatly appreciate it!
sorry for my bad english, but im so upset about this!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Replacing the housing i would presume that it was damaged with bend in frame? just guessing here.
If so a bend in the frame can cause fractures in the motherboard and cause Audio ic and Baseband issues causing no sound or no network.
As for the charging flex i would use the original due to most frames come with them pre fitted but they tend to be always faulty.
Fue útil esta respuesta?
Puntuación 1
Hello
i would say that you make almost all the diagnosis.. the replacement charging port is not good. Why don’t you use the old one ? There is some instructions to do this on this web site …
Puntuación 0
Añadir tu respuesta
ardi du estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 57
