Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
In June 2017 Apple updated its 13" MacBook Air with a newer Broadwell Intel Core i5 processor, resulting in slightly increased performance and battery life.
Preguntas 178 Ver todo
My battery is dying really quick. What could be the issue?
All of a sudden, my battery started to die really quickly. My battery used to last around 6-7 hours and now only lasts 2.5 hours on normal use. My Macbook is an year old. Apple Genius Guy says that there is liquid damage but my laptop is working just fine (other than the battery, of course). I even reset it. Still the battery life is the same 2.5 hours. Tried SMC and PRAM reset, no effect. I have attached coconutBattery’s screenshots.
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
Kits de Reparación de Pantalla LCD de iPhone
La opción de presupuesto, cubierta por nuestra garantía de por vida.
Compra kits
Reduce los costos de reparación, no la calidad.
Compra kits
3 Respuestas
Solución Elegida
Battery values are excellent, charging power seems to be flawless. I believe battery is innocent here and something is draining it beyond the acceptable..it might be a software or a hardware issue. To check what’s happening on software side, find activity monitor in utility folder inside applications folder. Launch it and select from menu to list “all processes” and see if there’s something using an unusual and unjustified amount of Cpu. Check what’s the average value of Cpu used during a normal session to see if anything is keeping it busy beyond the ordinary. If Cpu stays below 20% on average and battery gets drained at the speed you indicate something might be absorbing power on the hardware side.
Fue útil esta respuesta?
Puntuación 4
Let’s do some testing of your battery. Complete the guide below; upload 2 screenshots to your existing question, one with the MagSafe adapter in and one with with the MagSafe adapter out.
How to Test a Mac Laptop's Battery
Update (10/30/2018)
@mishragaurav Your full charge capacity is lower then your design capacity, it’s time for a new battery.
MacBook Air 13" (Late 2010-2017) Replacement Battery
Reemplazo de Batería de MacBook Air 13" (Principios de 2015)
Imagen de MacBook Air 13" (Late 2010-2017) Replacement Battery
Producto
$84.99
Imagen de MacBook Air 13" Early 2015 Batería
Guía
Dificultad:
Moderar
15 minutes
Imagen de Mac Laptop
Guía
Dificultad:
Muy fácil
3 - 5 minutes
Puntuación 1
Comentarios:
@ajcooke01 hi, thanks for taking time and effort to help me out. It really means a lot.
I have added the screenshots.
- Por
@ajcooke01 I agree battery is below full design capacity, but I (strongly) disagree a battery with such figures needs replacement..any battery after a few charging cycles is not 100% and every battery above 80% capacity can be considered good enough. Please include that in your battery testing guide ;)
- Por
@arbaman I have a hunch that it is just a crappy battery. Design capacity good or not, I think that is the scenario.
- Por
@ajcooke01 I have a hunch you have plenty of good will but a bit more of experience might help :) We all have a tendency to see troubles we know more often than the ones we don't have a clue about. That's the reason why doctors discourage people from self diagnosing =;)
- Por
As you can see by the pictures the battery is fairly degraded almost 30% less than normal also Is this battery aftermarket? I hope this can help
Update (10/30/2018)
OK, thanks thats what I needed to know did it start doing this after an update because this could be a software issue with mac OS and just an FYI apple will always say there is water damage because the sensors are set off even by a little bit of mist but you could try backing it up and resetting it
Puntuación 0
Comentarios:
Have a closer look, you're mistaken.
- Por
it says battery health is 62 percent and design capacity is 96.9% so that's where I got that, also have you tried backing up mac os and restoring it this could help the problem
- Por
The battery is original and out-of-the-box. As I told you, I bought it last September. The system is fairly new.
- Por
@ifixiphone David, I have restored and backed up the same but to no avail.
- Por
Oh sorry I didn't see that you already said that sorry
- Por
Mostrar 9 comentarios más
Añadir tu respuesta
Gaurav Mishra estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 11
Ultimos 7 días: 92
Ultimos 30 días: 293
Todo El Tiempo: 2,524
