Saltar al contenido principal
La actualización de marzo de 2015 del MacBook Air de 13" de Apple presenta procesadores Intel Core i5 e i7 de quinta generación, lo que resulta en un rendimiento ligeramente mayor y una mayor duración de la batería.
Preguntas 623 Ver todo
A few days back my MBA 2015stopped working. What could be the problem?
A few days back it simply stopped working. I put it on sleep and it never got on. Although, it could run the external mechanical hard drive up until 2 days after this. Following this, it stopped working. Tried SMC, NVRAM reset and everything. The fan won’t turn on too. There’s no chime. The Magsafe led would turn green when plugged into my Macbook. Any help would be appreciated. I do not remember spilling a drink on it, although I live in a pretty humid area.
Update:
When I do SMC, the light on my charger pin changes from orange to green but still the mac won’t turn on.
Update 2:
I have attached the battery’s screenshot. The LCI on the logic board is not triggered.
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Solución Elegida
Disconnect the mag-safe adapter. Disconnect the battery from the logic board. Press and hold the power on button for 10 seconds. hook the battery and mag-safe back up. You should get a spontaneous reboot.
Reemplazo de Batería de MacBook Air 13" (Principios de 2015)
Next download, install and run Coconut battery and post your results
How to Test a Mac Laptop Battery
Imagen de MacBook Air 13" Early 2015 Batería
Guía
Dificultad:
Moderado
15 minutes
Imagen de Mac Laptop
Guía
Dificultad:
Muy fácil
3 - 5 minutes
Fue útil esta respuesta?
Puntuación 3
4 comentarios:
Nothing happened. During SMC, the light is changing.
I have a MBA 2017 model, should I try its battery in the faulty one to check if the battery is at fault?
- de
It's compatible, give it a try. But, I'd do it the other way around so you can test the battery in the new machine.
- de
Thanks @mayer, I did the same. I have updated the battery's screenshot in my question. It still won't power up. No activity on the fan. I don't know what the problem is.
- de
- de
Añadir tu respuesta
Gaurav Mishra estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 163
