Apple iWatch face reseal
Glass came off of Apple Watch 42 mm need to reseal glass to watch.
Es esta una buena pregunta?
its best to have it done professionally, it could be that the battery has expanded and made the screen lift and if u try to force it back down it could break the screen. also the force touch sensor is almost like a little gasket in between the lcd and frame and its easy to damage
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 311
2 comentarios
The battery is ok. My daughter somehow opened the glass by trying to charge it when I first gave it to her. The watch is working normally except for the glass top not sealed to base.
- de fgsamm
And how do you know the battery is OK? If it lifted while it was on charge it sounds to me like the battery expanded and pushed open the screen. Did you remove the screen and visually inspect the battery?
- de lukerockhill
