Problem with pression point/spot blue doing screen replacement.
Am i the only one or are you guys encoutering some problems with iPhone 7 LCD also?
Now i’m removing the low retaining bracket to be able to fit in my LCD. Note : This is the OEM quality here in Montreal. (a friend told me that he’s installing the flex cable under the metal plac,but i preffer without the bracket then leaving my flex cable hanging out unfixed).
So,what do you guys do when something like that happens?
Thank you!
Es esta una buena pregunta?
5 comentarios
I'm not seeing anything wrong with the screen? I'm on a crappy laptop so might be the reason but still. Is anything wrong, like you can't tap in that spot?
- de Dave Feil
Without the bracket he wont feet in and that's a light spot also. Not normal at all.
- de DouglasVinicio
Like subtly brighter or..?
- de Dave Feil
In a photo it could looks like its subtly,but trust me it is not.
- de DouglasVinicio
The second photo you can see that the frame aren't touching the body. It is easy to see.
- de DouglasVinicio
