Saltar al contenido principal
La versión mejorada de Nintendo de Nintendo 3DS. Cuenta con pantallas más grandes, mayor duración de la batería, mejor densidad de píxeles y un mejor diseño.
Preguntas 411 Ver todo
O3ds xl blue light on but screen blank
I started up my 3ds, but the screen was just blank and no blue light so I removed the back to reinput the battery. When I screwed off the back I saw a puddle of water! I dryed it and blow dried it. When I tried turning It on the blue light showed and my splash screen showed too. I thought it was fixed but the screen turned blank after the splash screen :/ any ideas? I have luma3ds CFW and lots of save data I would hate to lose …..
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
After you've dried your 3ds try getting to cfw menu… you need to be a contortionist or have another hand,
Press and hold L & R shoulder buttons, up, a and then press power.
You should be able to go through the cfw menu and find the settings to reboot. Took me few goes but eventually I found it and the 3ds woke up.
You may need to have SD card with cfw loaded in 3ds.
Fue útil esta respuesta?
Puntuación 1
Respuesta Más Útil
Hi @senorpenguins ,
As you know water and electronics and electricity are not a good mix.
The water causes corrosion and provides circuit paths for the electricity which were not in the console’s operating design and could damage the components.
First do not turn on your console and then with it turned off you need to remove the battery as soon as possible to minimize any further damage.''
Then you need to dis-assemble the rest of the device and clean all the affected parts using Isopropyl Alcohol 90%+ (available from electronic parts stores and some pharmacies) to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain scents and other ingredients and is not as effective. If you do check the label to verify the amount of IPA.
Here is a link that describes the process.
Electronics Water Damage
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the console might possibly work correctly again.
Here is a link to the ifixit guide(s) for repairing your console.
Nintendo 3DS XL
If this process seems too daunting, take your console to a reputable, professional electronics repair service experienced in water damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Puntuación 1
Añadir tu respuesta
Senor Penguins estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 7
Todo El Tiempo: 236
