Right front power window motor replacement
Replace power window motor
Es esta una buena pregunta?
Hey, Chris. To access your window motor you’ll need to remove the door panel. Here’s a link to a video of someone removing the door panel and window motor of a similar vintage truck. This video is for the driver’s side door, but the steps will be the same for the passenger side other than a different switch assembly. Unfortunately, it’s possible that your window regulator is either welded or riveted in place, and will need to be drilled out. This means you will need to rivet the new one in as well or bolt it in place.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 51
