Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
A1418 | EMC 2889 | Finales de 2015 | Intel Core i5 de doble núcleo a 1,6 GHz o Intel Core i5 de cuatro núcleos a 2,8 GHz. Lanzado el 13 de octubre de 2015.
Hard drive upgrade not working?
iMac 2015, 8Gb, 1TB. Running Mac OS X Mojave. Used iFixit hard drive upgrade kit with Samsung 860 Evo 1TB SSD.
Opened in 10 minutes, disk pout in 5. Toughest bit was getting the new adhesive strips fitted - took ages to line up!
Now the tough bit.
I had cloned the drive, had to format as APFS, as when I did it as Mac OS Extended (Journaled) didn’t boot, and so I had to redo the clone.
Boots fine from USB port, bit when in the iMac, won’t boot - instead I get a folder icon with “?” in the middle. Reinstalled Had drive, and it went fine, so no probs with iMac. Also, rebooted from SSD with no issues.
Tried in iMac again, still no luck. Now back with Hard disk, and screen held on with tape.
What to do?
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
1 Respuesta
Solución Elegida
Cloning pretty well went out with the advent of the repair partition.
Todays method is to do a clean system installation (which gives you the repair partition. Now use Migration Assistant to move your data to the new drive.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Stephen Babbage estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 12
Todo El Tiempo: 417
