Saltar al contenido principal
The Lenovo IdeaPad 300-17ISK is a 17-inch laptop which was released in October 2016. The Model number is 80QH008MUS.
My device won't power on
My model is actually the ideapad 320-15abr. My issue is it won’t power on unless I do the reset procedure by removing battery holding down power. I have to do this every time and only works some of the time. Last time I left it on and it was completely off two days later and will not power on. All diagnostic tests came back good.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
HI:
Going out on a limb here but I think your power supply is hooped.
Or failing or faulty. This could include the plug at the end or even the power plug at the laptop may be broken or faulty inside. If you can borrow another supply or even take the units to a friendly computer shop for a quick check.
This trouble could go all the way to your motherboard.
Have worked on hundreds of laptops but this is a strange one.
Good luck
AB
Fue útil esta respuesta?
Puntuación 0
If your laptop is showing no signs of life and refuses to turn on, use this Lenovo IdeaPad U530 Touch Does Not Turn On problem page for possible causes and solutions.
Puntuación 0
Añadir tu respuesta
chrisellis87 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 301
