Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Crazy max capacity reading on battery
The battery for my old G4 iBook wouldn't hold a charge, so I replaced it. But I've been puzzled about the weird readings I was getting on the bad battery. Using either MiniBatteryLogger or Battery Health Monitor, I could see the capacity of the battery would range from 57800 to 60360 mAh. Clearly that makes no sense -- it's an original Apple battery that should clock in at 4400, I think.
I don't have any hopes of reviving this battery. But I'm just curious if anyone might know why it would give such a crazy reading.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
I don't know what causes this, but I've seen many batteries do it, and some of them even worked fine despite the crazy readings. It's definitely not a hardware problem with the computer, because it's battery specific and the next battery you put in may not have that issue, as you have seen.
Fue útil esta respuesta?
Puntuación 2
Could be a bad DC-in, or just an aging logic board.
Strangely enough, I have a vague recollection of someone posting something similar here some time.
Puntuación 1
Comentarios:
Thanks for the reply! But I don't think it's either of those things, since the replacement battery works fine and shows normal readings. I'm pretty certain it's something with the first battery itself, not the computer.
- de
well if it's OEM then that would be very strange.
- de
Añadir tu respuesta
mister790 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 1,014
