Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
iPad Air Wi-Fi + Cellular, modelo Nº. A1475. Disponible en gris espacial o plateado, con configuraciones de 16/32/64/128 GB.
Preguntas 116 Ver todo
Replacement of cracked ipad screen
My ipad screen cracked like in the picture. Ipad display can be seen and the touch responses well.
I want to fix it myself and am planning to buy the screen. But there’s a lot of choices; cheap or expensive ones.
Can i buy a screen like this? https://www.lazada.com.my/products/white...
Update (09/28/2018)
Can you give me an example of what kind of parts should I buy? I’m also confused on what to buy because I found out there’s a few variations of screens; lcd/digitizer/touchscreen/etc.
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
Kits para Nintendo Switch
Una solución rápida para volver al juego
Comprar kits de Switch
1 Respuesta
Solución Elegida
Sure you can do this yourself! You have to have a steady hand and be patient in your work otherwise you will create problems for yourself. I would recommend you read through this guide first to see if you are comfortable with the steps and tools required.
As for the parts, I can’t speak for the supplier you linked. However my one piece of advice here is don’t go for the lowest cost parts, ultimately, you always get what you pay for. Look for a reputable vendor that offers a real warranty and return policy. then if they have a premium or OEM version of the part, go for that if your budget permits.
Fue útil esta respuesta?
Puntuación 3
Comentarios:
Everything is listed out in the guide.
- de
Añadir tu respuesta
tikus belon estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 9
Todo El Tiempo: 119
