Saltar al contenido principal
Lanzado el 25 de septiembre de 2015. Modelo A1687 / A1634. La Reparación de este dispositivo es similar a las generaciones anteriores, requiriendo destornilladores y herramientas de palanca. Disponible como GSM o CDMA / 16, 64 o 128 GB / Silver, Gold, Space Grey o Rose Gold.
Preguntas 1041 Ver todo
iPhone 6s plus rear camera won't stop shaking and can't focus
Any suggestions to fix?
Es esta una buena pregunta?
Puntuación 4
Agregar un comentario
8 Respuestas
Solución Elegida
This is most likely an issue with the rear camera itself as it contains an image stabilization system and it can fail. You will need to try a new camera to see if that solves the issue or not but unfortunately, it is a very expensive replacement part.
Fue útil esta respuesta?
Puntuación 6
I had the same problem with my iPhone 6s Plus camera.I read that someone said to place a magnet near the bottom of the rear camera lens so I tried it and it worked.
Puntuación 3
4 comentarios:
absolutely works.. thanks for that
- de
I put one of screws from inside instead of magnet. It did work!
Thanks for the info!!
- de
It does work! But when you remove the magnet the camera begins to shake again
- de
Mine is shaking
- de
I saw on the internet a guy told me to get a refrigerator magnet and place it near the rear camera and it worked.I had to crack the magnet and take a small piece and glue it next to the lens on the bottom (if you use a phone case make sure the magnet is small enough but doesn’t cover the camera.)
Puntuación 0
1 comentario:
On the case or the front of the phone?
- de
I found a simple fix for this I hope it will help
https://m.youtube.com/watch?v=4z8GCVXCtY...
Puntuación 0
I found a simple and quick fix I hope it will helps
Puntuación 0
Put a magnet in the top right corner of your phone…PROBLEM SOLVED
Puntuación 0
1 comentario:
https://youtu.be/4-HaLRGm234
this is perfect and free
Puntuación 0
I went to Home Depot and pulled a dime sized neodymium magnet pack off the shelf and rubbed the magnets in small circles on my phone screen right where the camera is located underneath. After doing that for a few seconds I went back in the camera app and tested to see if the shaking stopped, and it did! I put the magnet pack back on the shelf and went home with a smile!
There is a magnet in your camera housing that’s became demagnetized somehow… get a powerful enough magnet like the neodymium one I found at Home Depot and remagnetize your camera. It worked like a charm and my camera is perfect again. It was fixed instantly, and didn’t cost a dime! :)
Puntuación 0
1 comentario:
OMG! Thanks, it really worked!
- de
Añadir tu respuesta
brandon estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 21
Todo El Tiempo: 37,098
