Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Lanzado el 25 de septiembre de 2015. Modelo A1688 / A1633 . La reparación de este dispositivo es similar a las generaciones anteriores, que requieren destornilladores y herramientas de palanca. Disponible como GSM o CDMA / 16 , 64 , o 128 GB / plata, oro, gris espacio, o la opcion de oro rosa.
Preguntas 2486 Ver todo
Pressure spot after screen replacement?
Replaced a severely cracked screen on my friend’s iPhone 6S so I could use it temporarily while waiting for the next gen to come out. Have replaced several screens and am pretty confident at this point.
After replacement, I see a spot (~1x1/4” at the top center of the screen). This spot is only there when the phone is completely reassembled. When i turn it on before the screen is snapped back into the case the screen is fine.
Is this caused by some sort of pressure from under the screen? I’ve removed some of the padding that the connectors come with but this does not help the issue. Anyone ever experienced this before?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
3 Respuestas
Solución Elegida
Don’t remove the padding from the connectors, those pads/cushions/sponges are there to insure the connector stays fully seated even after a minor impact.
If you are seeing a white spot, that is indeed caused by a pressure spot. Based on where you say it is, it sounds like its caused by the earpiece/sensor flex bracket or the IC on the screen flex (see the picture here). It is probably not sitting properly within the housing. Also check the battery to insure it is inflated, the black skin around the battery should be very tight, like shrink wrap.
Imagen de iPhone 6s Screen
Producto
iPhone 6s Screen
$54.99
Fue útil esta respuesta?
Puntuación 3
For the iPhone 6 in particular, the pressure-spot will occur if the ribbon Cable is slightly longer than the section on the frame (See Image) allows for.
This is an issue that can occur when using an aftermarket screen. If you purchased the screen recently, I would suggest asking for a replacement as this is a manufacturing defect. This issue happens when the size of aftermarket chips, frame, and even ribbon cables are not proportioned the same as OEM screens.
Puntuación 2
Comentarios:
Thank you so much for this information, you saved my butt!!
- de
I get this a lot on the iPhone 6s, the screen does not need to be changed out for another one. Simply that rectangle justs needs to be pushed up a little more closer to the top so that it makes clearance from touching the logic board which causes this pressure spot at the top of the screen on the middle column.
You can either push it up then quickly close it up or disconnect the screen with the battery unplugged and use scotch tape to keep it pulled up closer to the top of the screen.
See this image for reference:
Puntuación 1
Añadir tu respuesta
egotistdown estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 14
Ultimos 30 días: 51
Todo El Tiempo: 2,318
