iPad mini won’t stay on after digitiser replacement
I’ve just replaced the digitiser on my son’s iPad mini 2. When I turn it on the Apple logo appears and then the iPad turns itself off.
The only way way to get it to turn on again is to disconnect and then reconnect the battery.
If hold the power button and home button I get the same thing. Apple logo appears but then goes off.
Its not a backlight issue as the logo he logo appears fully backlit before disappearing.
Es esta una buena pregunta?
3 comentarios
I would recheck everything you did - Looking at the procedure, it seems like it would be really easy to damage the cable or connector while disassembling - also - did you use a new OEM quality part or a used/off brand part? Maybe defective part?
- de Lee
Thanks for the reply.
I’ve double checked everything and can’t see anything obvious.
It’s not an OEM part but could a faulty digitizer cause it to turn off?
- de stewart
try changing the battery, it should be ok
- de hemnnabaz
