Saltar al contenido principal
Información y guías de reparación para el iPhone 6 que salió a la venta el 19 de septiembre de 2014. Números de modelo: A1549, A1586 y A1589
Preguntas 4994 Ver todo
Back light coil L1503 Digikey supply
Has anybody ordered backlight coils off Digikey (fot the iphone 6,6s,7)and if so what is the part number they are using please?
I have read somewhere that the same specs as written in the schematic to match up on Digikey, the size is slightly different so this person setteled on a slightly lower rating to match the size
Thanks
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
The problem with some of the components that Apple uses in their designs is that they are either custom designs or only available with huge MOQ. You are correct that the Digikey models will not work as they are 2.8mm square and they simply will not fit. Some coils on the backside of the board are also hard to source because they are only 0.6mm high and everything standard is 1mm. It doesn’t sound like much but when you consider the density and clearance available, it makes a huge difference.
As for L1503, I order them from China. However, be aware that you never really know what you are getting because they are not “officially” labeled. I once ordered a batch from Jestar, a reputable supplier and when I checked them with an LCR meter, I realized that they were 1uH and not 15uH.
If you are going to using a different rating, keep in mind which ratings do what. For a coil, you have the inductance, the current rating and the ESR (equivalent series resistance). Using a slightly different inductance may or may not cause issues. The ESR is important because it causes internal heating and can have an effect on the overall performance (resistors, capacitors and coils interact and cause all kinds of filtering actions). Finally the current rating is what can make a permanent repair into a ticking time-bomb :>).
There are plenty of people selling this coil both stateside and internationally, that’s the preferred option.
Fue útil esta respuesta?
Puntuación 2
1 comentario:
Thanks Minho. I have just ordered a few IC's from that same supplier week ago, but have also recently read that what they are selling is junk. Can only give it a go. Trial and error. Thanks for your time
- de
I recently purchased these inductors from RS Components here in Australia.
Murata LQH2HPN150MJRL
But any 2.0 x 2.5mm Inductor should fit. Just check the specs are the same.
These fit very nicely and can be soldered either by hand or hot air. It has slightly less DC resistance but I don’t see that being an issue. Less DC resistance = less heat generated.
Puntuación 0
Añadir tu respuesta
Lee estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 138
