Saltar al contenido principal
Lanzado el 4 de noviembre de 2017. Modelo A1865, A1901. Disponible como GSM o CDMA / 64 o 256 GB / Silver o Space Gray. (Se pronuncia igual que "iPhone 10.")
Preguntas 1198 Ver todo
please help! iPhone x touch screen not working
iphone x touch screen not working i already change new display still haveing the same problem with new screen can any one help to give me the solution
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
No touch on iPhone X can be caused by a lack of communication between the top board and the bottom board—such as in water damage. The top board alone will boot but you will have no touch.
What is the full history of this device and your physical exam findings?
Fue útil esta respuesta?
Puntuación 2
2 comentarios:
HI THANK YOU MADAM
i have iphone x still touch not working i already put new lcd but the same coundition maybe its not a water damage there is not showing any water fungus still good mother board mam give me any solution !!
- de
Again--what is the FULL HISTORY of the device. There is no magic wand "solution" There is only troubleshooting. You must be a detective---this means combining ALL the evidence. The history, when was it last working, what happened to it when the problem started, what have you done so far, what is the physical appearance of the housing, what is the physical appearance of the logic board. Does it work in a known good housing, what are the diode mode measurements of the lines important for touch at the connect--are any of them wrong, if so, why.....
The solution is "Use your brain and begin logically troubleshooting this board like a detective"
- de
I have same problem
i replaced new lcd but the problem still
can any one help
Puntuación 0
Añadir tu respuesta
Nasif ali estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 907
