Saltar al contenido principal
Modelo A1224 / principios de 2009 / 2.66 GHz Procesador Core 2 Duo
Preguntas 104 Ver todo
Pregunta Cerrada
What is the interface of my ODD?
System info of my iMac (model 2266) shows the interface is ATAPI. I plan to swap ODD with SSD.
I ordered SSD enclosure with SATA interface. Can I put this in the place of ODD?
I also plan to out the ODD. Can I use an outcase with SATA interface?
What is the hight of my ODD?
Es esta una buena pregunta?
Puntuación 0
3 comentarios
This question was migrated from http://meta.ifixit.com/.
- de
thank you for migration.
- de
I opened it and found that it was actually SATA. SATA to SATA caddy is the necessary part.
- de
Agregar un comentario
1 Respuesta
Solución Elegida
UPDATED
You should be fine. The SATA interface is for the SSD drive, not the interface with the logic board. To check, please give a link to the optical bay adapter you ordered.
As you can see in the photo, the optical drive has a standard SATA connection. So the adapter you are looking at should plug right in.
Fue útil esta respuesta?
Puntuación 2
8 comentarios:
I don't see a problem with that one working, to be sure contact the seller.
- de
So you mean that so long as the SSD is connected to the hdd caddy with sata interface, there is no connection problem in connecting this caddy to thw logic board?
I want to be comfortable before I dismantle iMac and tear out the odd..
- de
See my updated answer with photo
- de
Thank you very much indeed.
- de
Mostrar 3 comentarios más
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 2,506
