Saltar al contenido principal
El iPhone 5c de Apple fue anunciado el 10 de septiembre de 2013. La reparación de este dispositivo es similar a los modelos anteriores, y requiere destornilladores y herramientas de entrometimiento. Disponible como GSM o CDMA / 8, 16, 32 GB / Blanco, Rosa, Amarillo, Azul y Verde
Preguntas 1232 Ver todo
Phone not turning on after falling
Yesterday, my phone fell down while using. Now when i’m trying to turn on, it won’t. I need to hit the back panel or press the center part of the screen to turn it on.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
Seeing as how this is an iPhone 5C, it’s probably not the first time it has take a fall :>).
This could be as simple as a partially disconnected connector or as complex as a logic board issue. You could start by opening the device to see if everything is connected properly. If that looks good, then try to connect it to an iTunes enabled computer . If iTunes can see the device, then the issue may be screen related only. If iTunes can’t see the device, then it could be logic board related.
To properly troubleshoot this issue, you will eventually need access to some known-good replacement parts or find a shop that will be willing to do the troubleshooting for you.
Fue útil esta respuesta?
Puntuación 1
1 comentario:
Yes it is a second hand phone. I will follow your instruction and hope it works.
- de
Try opening up your phone and try to disconnect and connect again the battery ribbon.
Puntuación 0
Añadir tu respuesta
Saikiran Bait estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 106
