pump runs 10 + minutes until it codes out F2
Similar situation: new pump installed. Run any cycle and a small amount of water shoots in then the pump runs 10 + minutes until it codes out F2. Drain line is clear. Tied to pressure sensor? Pressure tube appears to enter back of washer. Can it clog?
Es esta una buena pregunta?
1 comentario
a_riddle1 is this the same situation that prompted you to replace the pump? What is the exact model number for your washer?
- de oldturkey03
