Saltar al contenido principal
Modelo A1419 / Finales de 2013 / 3.2 y 3.4 GHz Procesador Core i5 o 3.5 GHz Core i7, ID iMac14,2
Preguntas 322 Ver todo
Late 2013 iMac failing ASD CPU test and shutting off
Hi all!
We had a late 2013 iMac come in with booting issues. It would go halfway and shut off.
I figured a bad update screwed things up so I reinstalled OS-X. Same thing. Ran Apple Service Diagnostic and it shut down on CPU test.
It would pass whetstone and fail on dhystone and linpack. To me this was open and closed CPU failure. Replaced the CPU and all was OK for a few days. It passed 21 iterations of ASD. Customer gets it back and it doesnt turn on again this morning.
Given that the CPU tests were failing, I don’t know what more it could be.. Another odd thing it does is once it shuts down, it will not turn on unless you do a NVRAM reset.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Did you check the CPU’s VRM logic? The coils, caps & the MOSFET’s
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
TCRS Circuit estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 163
