Saltar al contenido principal
The TI-84 Plus CE is a graphing calculator released in Spring 2015 by Texas Instruments. It includes a 2.8 inch color screen, USB port, apps, storage, and a 1200 mAh battery.
Preguntas 44 Ver todo
Where can I fix my charging port?
My charging port is damaged and I need to know how to fix it
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 0
Agregar un comentario
Kits de Reparación de Batería de MacBook Air
A partir de $69.99
Buy Now
A partir de $69.99
Buy Now
1 Respuesta
Respuesta Más Útil
I don’t know how damaged your port is, but I assume you want to replace it? I’ve never done this myself, but I don’t think it’ll be easy; you probably need some skills with soldering. This is how I assume the process would go:
First, you’ll need to find a donor device that has a working, mini USB port (a cheap, broken TI 84 Plus CE should do). Then you’ll need to desolder the port from the donor device.
Next, you’ll need to take apart the calculator to reach the motherboard. Then need to carefully peel away the foil covering the mini USB port. It may be a good idea to remove the battery.
Next you’ll need to desolder the damaged mini USB port and solder on the new one. Replace the foil and the battery, then close up the calculator.
If you calculator still turns on, that’s a good sign. If the calculator charges normally, (check by plugging in the USB cable into the port and seeing if the battery indicator turns orange.) then great! If your computer recognizes that your calculator has connected to it, then data transfer is still working!
If you messed something up and your calculator no longer functions, you may want to use your warranty if it still applies.
Hopefully that helped…
Fue útil esta respuesta?
Calificación 1
Añadir tu respuesta
Santiago matias estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 3
Últimos 30 Días: 18
Todo El Tiempo: 145
