Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
El mando (controlador) inalámbrico Xbox One 1697 se lanzó en 2015 y reemplazó al controlador 1537 y soluciona algunos de los problemas encontrados en los controladores modelo 1537. El controlador modelo 1697 incluye un conector para auriculares integrado de 3,5 mm, que permite la compatibilidad con la mayoría de los auriculares de terceros sin adaptador. Este controlador ha sido descontinuado y reemplazado por el controlador Modelo 1708.
Why is my right trigger always activated even when i'm not pressing it
My right trigger has been like this for a year now i am going to open it up once i get the tools and i am wondering if anyone knows what is wrong and how to fix it.
Thanks
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
2 Respuestas
Solución Elegida
If the right trigger is faulty . When you open it up , you will notice that the trigger makes contact with part of the board ,it may be spring that the trigger makes contact with maybe faulty or maybe need to be cleaned out .if u do open it up try n use 99% alcohol to clean it out of it is messed up . Also the part the trigger makes contact with may be going bad especially if it acting with out you touching it.
Fue útil esta respuesta?
Puntuación 2
1 comentario:
Would Lysol Disenfectant spray work?
- de
What I do is hit the RT or the faulty button really hard with my hand and after a few times, it worked. Not that I necessarily recommended this as the problem does come back occasionally. Do this at your own risk
Puntuación 2
1 comentario:
Wtf i just gave it a shot and it actually worked, thank you ive been tryna open it and I don't got the torx screwdriver I was looking around for a bit then I decided to look online and boom seen this and I gave it a wild shot and it actually worked like wtf so many controllers I got rid of I could've just done that😂
- de
Añadir tu respuesta
Bailey Smith estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 12
Ultimos 30 días: 77
Todo El Tiempo: 23,832
