Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Modelo A1224 / mediados de 2007 y principios de 2008/2, 2,4, o 2,66 GHz Procesador Core 2 Duo
Preguntas 622 Ver todo
White thermal paste vs Arctic Silver?
Any idea why the thermal paste on the iMac video card's two RAM chips is the white spongy type, instead of something like Arctic Silver, as is used on the graphics chip itself? Can Arctic Silver be substituted for the white paste?
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
Kit de Destornilladores Manta
112 bits for every fix.
Upgrade Your Toolbox
1 Respuesta
Solución Elegida
Most of the pros on iFixit recommend and use Arctic Silver 5. I'm sure China uses its own brand. I've seen some white powder stuff on RAM but never a thermal paste.
Fue útil esta respuesta?
Puntuación 2
Comentarios:
I'd normally use Arctic Silver on everything too, especially since when I tried some cheap white paste years ago, it didn't work as well. But I'm wondering if Apple had some reason for using the odd spongy white stuff I'm seeing on the VRAM chips. One guess is that, since VRAM doesn't get as hot as the GPU, it may not need the better, more expensive stuff. But since I'm replacing the dried-out Arctic Silver-like paste that Apple used on the GPU, with actual Arctic Silver (which may not be any better than the gray paste Apple used), I figure if it can't do any harm, I'd replace Apple's white paste with Arctic Silver too, unless there's some reason not to (which I can't imagine, but I've been wrong on something once before).
- de
I just wouldn't use thermal paste of RAM. If you're really worried about RAM heat, try using heat sinks made for RAM. You can get these for like $1.00. Here's a bunch: http://shop.ebay.com/items/ram%20heatsin...
- de
Añadir tu respuesta
johnsawyercjs estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 43
Todo El Tiempo: 3,866
