Saltar al contenido principal
Modelo A1297 Unibody: principios de 2009, mediados de 2009, mediados de 2010, principios de 2011 y finales de 2011
Preguntas 544 Ver todo
Is my MacBook Pro 17” doomed?!
I’m trying to figure out if my MBP 17” is doomed for good or if there is hope to fix it. I’m not as technical as I used to me so I’m lacking in technical terms. Here’s the history of what has happened and I’m hoping a few can give feedback on how to proceed. I’m a graphic designer and can work from anywhere so I loved the 17” size.
I purchased my laptop used from a reliable computer repair shop on eBay back in summer 2016. I’m not sure if the logic board was replaced but even if it was, I know the recall is no longer valid.
Everything was working fine until funky lines showed up on my screen. Eventually, my screen started locking up and the computer would reboot. Sometimes it would reboot to the regular home screen but it got to the point where it would reboot then just go to the blank grey screen. I brought it into the Genius Bar and they ran an diagnostic test. Everything checked out good except for the battery and hard drive. I knew the battery was going but was surprised by the hard drive. The tech recommended I get a SSD. I was about to order one when I remembered I upgraded to a Samsung SSD when I bought the laptop. When I went back to the tech and told him, he said he was surprised that drive was failing but luckily it is still under warranty.
I recently bought a newer used genuine Apple battery with a low cycle number and installed that. The same issues still happen and I can use the laptop for a few minutes before it freezes and restarts.
I’ve been reading up on all the issues the 2011 laptop and I’m a little overwhelmed by them and Apple’s lack of help considering the problems have continued beyond replacements. I’ve been using Apple computers since the early 90s but definitely feel they care less about us designers who have been devoted users from the beginning!
My question is…..is it really the hard drive or is it one of the many logic or motherboard issues that are haunting the 2011 laptops? I’m hesitant to send back my SSD as I really don’t think that is the issue. I’d like to hold on to it if I can install it into another laptop.
Is it worth it to try and fix this, or impossible as parts are hard to find and install now? If not, and you recommend I hold onto the SSD and battery, which model/year do you recommend I upgrade to that will work with my SSD and battery. I use Adobe CC everyday with InDesign as 80% of my usage. No heavy duty photoshoping or videos. I was thinking of a 2015? What should I do with my 17”?
Any advice would be greatly appreciated!
-Melissa
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
In my experience the issues described point quite clearly to a graphic card issue. Electronics is a complicated world but in my opinion it’s quite useless to point attention to other directions such as battery or Ssd just because they’re easier to tackle..a waste of time and money. Nowadays you could buy a brand new small Ssd and a new drive flat cable for something like 50$/€ and try installing a clean Os on that, but I bet you’ll end up throwing away another bit of money for nothing. Depending on where you are you might be able to find a reputable lab dedicated to Mac repairs where they do replace graphic cards with new reliable ones..it won’t be cheap but 17” are beautiful Macs and for you a favorite working tool, thus well worth the expense. Your Ssd can run on any Mac, depending on the Os you have installed on it..I’d avoid sending it for replacement, it’s very likely it doesn’t have anything to do with your issues.
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
MelH estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 43
