Saltar al contenido principal
Slide to unlock and turn off won't work after installing new display
Just installed IFIXIT’s display assembly and “slide to unlock” doesn’t work nor does the slide to power off function. Hard reset does work but just gets me back to
. I received the phone with broken screen from my daughter who was using the “assertive touch feature. See whitish circle at 3 o’clock on photo of screen. Hitting that opens up choices but the hitting the icons doesn’t seem to do anything.
thanks for your thoughts
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
Turns out the new display from Ifixit is bad. I tried it in a second iphone 5 and it didn’t worth properly in that one either. I could not fully enter my 4 digit pass code in the second phone. I have requested a return/exchange approval from ifixit.
Fue útil esta respuesta?
Puntuación 0
Respuesta Más Útil
It sounds like you have a or some dead zones on the digitizer. This could be caused by a faulty replacement screen or something went wrong during the installation. Open up the device again and closely inspect the flexible connectors coming from the screen. Also take a close look at the connectors on both the flexes and the logic board. If you see any damage or debris, that could be the cause.
Puntuación 2
1 comentario:
Thank you for your reply!
I’m now thinking I couldn’t turn it off before I put on the new digitizer. Secondly, the battery is bad. I had to use a heat gun yesterday to get it started. I fully charged it but this morning it was completely discharged, this is it again showed just the battery outline and a narrow red section. So I will check the connections closely when I install the new battery . Yes, I could be throwing away “good money after bad”.
- de
Añadir tu respuesta
Steve S estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 47
