Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Una cámara compacta avanzada de gama alta fabricada por Canon.
Camera got wet doesn't power up
I have a Canon SX50 HS or should I say I did have.
Stupidly, I left it out in the rain one night, got distracted by the kids.
Worked ok for a few weeks and then decided to give up the ghost.
Now it will not turn on.
I tried replacing the external battery, no luck.
I read on this site that cameras have an internal battery.
Does the Canon SX50 HS have an internal battery?
This happened a few months ago now and still doesn’t power up. So I suspect it will be dry inside now but some type of damage has been done.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
William Jackson  dry maybe but also corroded. you will have to disassemble Canon PowerShot SX50 HS your camera and clean it properly. Use some 90%+ isopropyl alcohol and a soft brush then clean all the parts with it.
This should help you out aswell
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
William Jackson estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 10
Todo El Tiempo: 657
