Saltar al contenido principal
Intel Core i5 de doble núcleo a 1,8 GHz (Turbo Boost de hasta 2,8 GHz) con 3 MB de caché L3 compartida
Preguntas 371 Ver todo
Boots up when insert battery, can’t shut off
I am trying to replace a battery in a MacBook Air and as soon as I put the new battery in, the device boots up. If I then turn it off, it boots up again within a few seconds. It seems impossible to turn it off so it stays off. Does this mean there has been a short somewhere? There was no water damage that I know of (not my machine).
Thanks!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Reset SMC by Pressing shift + control + esc and use power button to boot into recovery mode in that there is an option to reset SMC
Fue útil esta respuesta?
Puntuación 0
1 comentario:
Thank you for the reply!
Actually right after this comment I tried putting the new battery in again, and when it booted up I held the power button down to turn it off. Now, instead of starting up again right away by itself like it used to, it won´t turn on at all, even when plugged in with power cable. So not sure what´s going on there. Would this be a logic board issue?
- de
Añadir tu respuesta
Vera estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 23
