Saltar al contenido principal
Lanzada el 3 de marzo de 2017, la Nintendo Switch es una consola de mano que se puede ver en la televisión o usarla tal cual.
Preguntas 443 Ver todo
No HDMI to TV using Nintendo Switch Dock after USB-C Port Replacement
Switch had a damaged USB-C port with broken pins. Replaced the USB-C port with a new one and now it charges fine and everything works great except for the Nintendo docking station to output to HDTV.
When I connect the Switch to the dock, it does receive a charge through it and the green light to indicate it’s outputting to an HDTV lights up, but no image or sound is produced on the TV.
I have already gone through Nintendo’s official troubleshooting steps with basic things like trying other TV’s, other HDMI cables, etc. I have tried different combinations of the order in which I plug the cables into the dock before I actually connect the Switch and none of that has made any difference. In fact, according to Nintendo, if I am getting the green light on the dock but there is still no image displayed on the TV, then I should send it in for repair. Heh.
So rather than drop close to $90 for an official Nintendo dock or $40 for a third-party dock, does anyone have any other suggestions? Is there any way to go about troubleshooting the controller board inside the docking station? Could the USB-C port I used to fix the no charging issue due to the damaged pins be to blame? Could the damage to the original USB-C port have caused other damage to diodes, resistors, ICs?
Thanks.
Es esta una buena pregunta?
Puntuación 4
Agregar un comentario
1 Respuesta
Solución Elegida
To anyone else facing this issue - Go back and check your soldering job on the USB-C port. The lower row of pins on the port was to blame. One or more of them may not have been soldered properly.
Fue útil esta respuesta?
Puntuación 4
Añadir tu respuesta
TechWizard estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 44
Ultimos 30 días: 179
Todo El Tiempo: 5,305
