Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Unveiled at the 2000 North American International Auto Show on January 10, 2000, the redesigned 2001 Dodge Caravan and 2001 Chrysler Town & Country were released for sale in August 2000.
Preguntas 185 Ver todo
hot gage poor heat
I own a 06 dodge grand caravan,engine heat gage is at normal but only cold air blows out...wht could this be? I was told it could be the thermostat but it could sldo be a sensor..
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
Kits para Nintendo Switch
Una solución rápida para volver al juego
Comprar kits de Switch
1 Respuesta
Solución Elegida
If the problem was your thermostat, you would still have some heat. So, likely, that is not the issue.
If you have just had your radiator flushed, then perhaps it was not refilled properly. Some vehicles, especially newer ones, have a 'procedure' to refill the cooling system. Some shops will wave that off and just return your vehicle. Your owners manual will have information on this. (Hmm, my idea of 'newer' is getting older. Sigh. :)
Another possibility is that like most cars, the controls you adjust are vacuum operated, and there is a break in a vacuum line.
Without knowing more details, it is hard to narrow it down.
Details like:
Have you had it serviced recently, and what was done?
Does the van have any other problems that started at the same time?
Except for not having warm air, does the ventilation system function as expected?
Tonka
Fue útil esta respuesta?
Puntuación 2
Comentarios:
+ good answer and very logical approach...
- de
Añadir tu respuesta
francisco estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 663
