Red Screen Boot Loop
I have a iPhone 5s that is stuck in boot loop and goes onto a red screen then starts the loop again, how can i fix it? Thanks!
Es esta una buena pregunta?
From my experience it’s either a bad front camera cable, Tristar chip (Charging chip that would need to be replaced via micro-soldering / board level repair) or at worst the NAND flash memory chip needing reprogramming and/or replacement.
Try unplugging the front camera cable then power it on again and see how that goes.
Reemplazo de Cámara frontal y cable de sensor frontal de iPhone 5S
Fue útil esta respuesta?
Thanks, i tried disconnecting the cable and it still happens, going by what you said i belive it will be a mothet board issue!
It is a board level issue like iphone 6 touch desaese
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 1,192
