Una consola de videojuegos producida por Sony Computer Entertainment, anunciada por primera vez el 20 de febrero, en 2013 y lanzada el 15 de noviembre en 2013.
Preguntas 887 Ver todo
Stock thermal paste around apu pins
Hi so I decided to replace the stock thermal paste on my PS4 and while I was doing it some old thermal paste went on or near the pin holes around the apu. Would this be a problem or can I leave it like that.? I already tried cleaning it the best I could with 70% isopropyl alcohol.
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Comentarios:
SMALL AMOUNT WONT HURT
i've done that many times adding a cpu in my pcs
cotton bud alcohol or even aftershave /perfume :) used
only way is to try if it works its ok (Y)
por
Oh okay thanks it is just a small amount as well and I did try my best to clean most of it gone
por
Agregar un comentario
¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
Visita Nuestra Tienda
1 Respuesta
Solución Elegida
Thermal paste is non-conductive and won’t interfere with any of the pins. While it is preferred that this not be all over the place, it will not cause problems with the function of the unit. You can try to remove it using alcohol or another solvent, but if the amount is small, leave it alone. You are more likely to cause issues attempting to remove it that you will solve.
Dan
Fue útil esta respuesta?
Calificación 0
Comentarios:
Yea I turned it on and it still works I cleaned it out with a bunch of alcohol and had a bit of the thermal paste around
por
Añadir tu respuesta
WheatSins estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 55
