tigris or tristar? ( how it works ) some strange problem
hello,
in facts:
iPhone 6s, no water damage, all is fine but... After every 5 minutes, when screen is off phone is going to kind of loop. Current consumption drops to 0,58-0,62 and oscillating on these values. Nothing work, just hanging. Disconnecting the battery is only helps.The same when charging by wall plug. The exception is when charging by usb (computer).
Questions:
how it work?
When phone works normally, power supply is implemented by PP_BAT_VCC to Tigris Chip (U2300) which is responsible for generating PP_VCC_MAIN. If the Lightning port is connected, (then Q2300 is "opens") and PP5V0_USB is used to generate PP_VCC_MAIN.
In my case, it looks like Tigris is not working properly. But when "hanging" PP_VCC_MAIN is ok (approx.V=4,2). This leads me to suppose that the circuit PP_BAT_VCC is damaged (somewhere).
Can anyone explain how the PP_BAT circiut works? (in logic)
- thanks
Es esta una buena pregunta?
