Bluetooth showing unavailable on MacBook Pro 13 inch 2009
I recently changed the battery, trackpad, and replaced the logic board.
Now the bluetooth is showing unavailable... Any ideas how to fix this?
Es esta una buena pregunta?
Did you access the AirPort its self? If you had you might have reversed the cables.
Fue útil esta respuesta?
Turns out it was a internal issue, I took the display apart, took off the clutch, and the cable that connected to the bluetooth card looked off, so i replugged it. Works fine now.
Happy all’s well - Don’t forget to score & accept the answer.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 208
1 comentario
Go into About this Mac> System Report, open the USB on the right do you see the Bluetooth Host Controller.
- de Dan
