Why is my ac not working?
Es esta una buena pregunta?
Menú
Tus configuraciones
The 2008-2012 Ford Escape features a revised front and rear fascia and restyled LED tail lamps.
Rep: 1
Sounds like your AC compressor could have gone out, does your vehicle still run heat? If so it is your compressor, usually these repairs run from around $200-$300 depending on the shop's labor charge. If your heat does not work, it could be the blower.
Comentarios:
Often times you get a refrigerant leak in either the hose or pipes which needs to be fixed before recharging the system. You don't want to run the AC without the refrigerant as you can damage it.
- Por Dan
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 98
